I'm trying to convert vhs tapes to dvd using a KWorld DVD Maker PCI card. I don't know the exact model number (I think it was on the bar code which I sent in for a rebate and never received.) First I tried the software that came with the card and got decent enough video on the resulting short capture that I did, but no sound whatsoever through the speakers or on the resulting file. Then I remembered that I have MainConcept, so I tried it. Same results - decent video but no sound.
Other than the issue of no sound, the card seems to work OK so far. I haven't tried to capture an entire movie yet, because of the sound problem. The very short (less than a minute or so) captures seem to be good. At least as good as I expected of an old vhs tape. Of course, I haven't yet tried to burn the results to a DVD.
I'm running XP with an Inel Core 2 Duo processor.
The audio source that automatically appears when I do the capture setup is Realtek AC97 Audio.
The capture source is Conexant 2388x Video Capture.
Could this be codec problem?
Help will be appreciated.
Hi I am having the same problem.I too have a Mac.......have downloaded Empia Capture which seems to play the video- but there is no sound coming out.Also I dont know where /how to plug the 4 pin S Video cord? The back of my VHS video player doesnt have a port/cord that suitsIt just has a "RF OUT" port which takes a male single pin....but then I dont know where to plucd the other end into the mac/ how? (if it needs an adapter) .I have no idea what transfers the sound- and makes it heard on my mac.Please help!
Michelle
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
kworld dvd maker 2 help
By itsicon in forum Capturing and VCRReplies: 39Last Post: 18th Dec 2010, 11:21 -
Kworld Expert dvd Maker - S-Video no picture
By johnstede in forum Capturing and VCRReplies: 3Last Post: 9th Aug 2009, 08:54 -
Problem with kworld dvd maker 2800D usb - Compression artefacts?
By jhowee in forum Capturing and VCRReplies: 5Last Post: 10th Feb 2008, 06:48 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
