Hello,
my camera is a sony hc7 and I use the rather expensive Sony HDV tapes.
Can I use the Sony HDV cassetes not replaced by another brand but with the same quality.
Thanks.
PeterK
you can use any miniDV tapes you want to. they don't have to say "HDV" they are the same. DVavi and HDV are recorded at the same bitrate on the tape so there is no need for a "better" tape for HDV.
only thing i wouldn't do is change brands in a single cam. different lubes can muck things up. i clean the heads on my business machines after every tape brand change. -
Well, there is supposed to be a difference in the quality. Since HDV isn't all I-Frame, the presence of dropouts on a tape causes more trouble, so the "higher quality" tape was meant to minimize that. Of course, YMMV so it most of the time doesn't make a big enough difference to warrant the extra cost (presumably built into the higher manufacturing specifications, or quality control).
Scott -
have you tried the Sony HDM-63VG? It's less than $7
I've never had a dropout on my Canon HV30 using these $3 Panasonic tapes
http://www.amazon.com/Panasonic-MiniDV-Tapes-Pack-5/dp/B00007FWP2"Quality is cool, but don't forget... Content is King!" -
my hv30 hasn't lost a frame yet using standard sony dvc tapes - dvm60prr - about $2. even reusing them 3 or 4 times hasn't been a problem.
What Mini DV Cassetes for HDV recording
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Jun 2011, 05:01 -
HDV (1440x1080) on mini DV cassetes
By MI6 in forum MediaReplies: 1Last Post: 19th Sep 2010, 14:32 -
HDV recording on mini DV cassetes
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Oct 2008, 06:25 -
HDV Camera and Cassetes
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Apr 2008, 18:37 -
Sony HDV Cams question.
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 17th Dec 2007, 05:15
