I thought it would be easy but I can't seem to find a way to do it.
I received a file from a friend but for some reason the audio runs too long and so it is out of sync in the middle but is in sync at the very beginning and very end.
I think I can fix it if I just compress the whole audio track down by about 1 minute.
Is this something that I can do in Audacity?
I hope I explained it well enough. I don't want to cut anything out of the audio track, I just want to push everything together a bit and reduce the time.
Under Audacity's effects, you could select Change Tempo, with will alter the duration without changing pitch. However, if your audio track is in sync at both the beginning and the end, but out of sync in the middle, your problem is a bit more complex, and the Audacity effect would likely create more problems than it cured. You say NOTHING about the audio format or how it was encoded. I suspect it has variable bitrate encoding, which is causing the sync inconsistencies. If that is the case, you could re-encode the audio track as constant bitrate.
These are just hypotheticals, since you provide no useful information about the audio file (or the video stream for that matter). -
Sorry about the lack of information but I wasn't really asking for help, just how to shrink the length down.
The audio file has a constant bit rate (I'm quite sure) but the problem with the file was that the video was messed up. The last part of the video would play twice. The file was longer than it should've been.
I have no idea how the heck he did that. I edited the video and removed the repeating section.
I can only assume that he used a program that automatically stretched out the audio to fit the messed up video. I'll try to see if I can fix it but if I can't then whatever.
Thanks for the help though. -
Huh?Originally Posted by darkzero297
If you post a problem that you're having, and asking how to solve it, that's asking for help.
Total running time
By mrcoolekin in forum Authoring (DVD)Replies: 26Last Post: 15th May 2009, 02:38 -
Maximum running time
By biged670 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2009, 18:39 -
DGPulldown and running time?
By ecc in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 04:23 -
Why am I getting this error message after running DVD Shrink?
By Soccerman77 in forum Video ConversionReplies: 9Last Post: 19th Oct 2007, 15:54 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 14:35
