DVD Author 3 shows grid lines and what will be seen on the TV. If the clip goes over the TV lines, is there a way to pad this so as to fit in the TV zone? Does DVD Author 4 have this capability?
The resize options in DVD 3 are : 1. Display at original size 2. Always fit to window 3. Fit if larger than window only.
This does absolutely nothing.
However, I can pad using XMedia Recode and it does a fine job. Why doesn't TMpGenc provide this capability?
Are you are talking about a menu background? I don't think that most authoring programs allow you to actually edit menu backgrounds beyond automatically resizing them to the correct PAl/NTSC resolution. People generally prepare them ahead of time using a grahics program when they want something else to happen, or use the standard background(s) provided by the software.
I do not use DVD Author, but regardless, I never use a DVD authoring program to do my menu graphics. You're likely going to have to use Photoshop or some other graphics image program to add 10% around all edges of your menu background. But your new image must remain at the required dimensions for backgrounds (i.e., either 720 x 480 or 640 x 480 for 4:3 aspect ratio; check DVD Author's requirements). Thus, you would have to shrink and drop the old background image inside the new background image to get the outer borders you need.
I have dvd author 2 but don't fool around too much with menus. I always use the stock settings and stock templates.
Are you sure the "fit to window" doesn't do anything? That would seem to be the logical choice to me.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yes I am sure-"Fit to Window" did nothing for me. However, "Xmedia Recode" did an excellent job. So, I can do it, but TDC 3 & 4 could included that as a nice option that would save time, or so I think? The background was in AVI annimation-not a JPG.
The last version of TDA that I tried did not support motion menus, so I assumed you were asking about a still menu. I don't know why it doesn't allow a moving background to be resized, or if later versions do.
GFD, which I use now, also does what you are asking for. I can resize animation to fit in a smaller space. It's freeware, versitile, and a very good program in many ways, but not as easy to use as TDA or TAW.
Problem padding with ffmpeg
By joesphroth in forum Video ConversionReplies: 8Last Post: 6th Dec 2011, 17:56 -
need to correct Aspect Ratio by padding/adding black bars - author AVCHD
By texas1 in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Nov 2011, 11:44 -
padding question for coversion to smartphone
By RdM642 in forum Video ConversionReplies: 0Last Post: 8th Sep 2010, 05:03 -
Add padding to videos
By marioval in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2009, 06:22 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 09:17
