Results 1 to 17 of 17
  1. Anonymous
    Guest
    Can anybody provide me
    any help or web link..
    for making Batch files for:
    1. disk check with options (chkdsk)
    2. copying data from one location to another.
    Thnkx.
    USA
    You might want to explain what you want to do better. If you want to do a unattended backup of data files from one drive to another, maybe a backup program like Acronis True Image or similar? Or you may be able to write a script that runs off the OS scheduler to do similar. More information would help.
    And this would be better answered in our Computer Forum. Moving you.
  3. Anonymous
    Guest
    Thnkx..
    OK here's the situation
    one folder having 5 sub folders in D:
    Another folder having 5 sub folders in E:
    Now I'll have to do it one by one
    i.e. from one sub folder to another sub folder
    So can I make a batch file, so that
    moving data from D: to E:
    can be done simultaneously.
    And about disk check,
    like I want to check all my 4 drives simultaneously
    with a single click on such a batch file.
    canada
    Open notepad and type in the folder destinations and save as run.bat,make sure you save as all files and not txt.
    eg:copy temp c:
    copy multi c:
  5. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    in notepad, if you save as "run.bat", with the quotes, it will save as a literal. You can do it with any text document, such as "homepage.html' for a web page.
  6. Anonymous
    Guest
    plz anybody...give me a tutorial for this
    I haven't dun this before.
    Thnkx.
  7. Member Soopafresh's Avatar
    Jan 2004
    "Quality is cool, but don't forget... Content is King!"
  8. The problem is, you have to tell windows to unmount the disk first. If this is you boot drive, you select yes, and it will add it to an AT command a next boot up.
    Or are you doing this on a nonboot drive or from a winxp boot disc?
    Originally Posted by jagabo
  9. Anonymous
    Guest
    I'm using vista...
    I'm not able to scan the C: (windows drive)
    not even during boot.
    It says: cannot run "chkdsk" for RAW drives.
    Thnkx.
  10. Anonymous
    Guest
    Awesome tutorial...
    Thnkx "Soopafresh"
  11. Member Cornucopia's Avatar
    Sounds like you have 2 totally different requirements.
    1st is Disk check, and that should be done on a regular basis and better done with a Boot/Repair Utility CD, so that all discs can be unmounted. This can easily be scripted.
    2nd is really Synchronized folders, which you could do with Windows itself. Just read the help info on synchronized folders (usually reserved for network-accessed drives, but you can do it with others). Or Google it. Beyond the OS, there are numerous apps that do file & folder synchronization and backup. Since synchronization is meant to be automatic (usually as a continuous background process), you don't really need to "script" it. Just pick the folders to be synced.
  12. You might want to skip old Command (DOS) commands altogether. The future is Powershell and scripting....Just us old birds hang on to batch files.
    In this case, you drive is showing up as raw Not formated in chkdsk.
    I would boot from your Vista disc and do it from there.
    I would venture to guess your computer has 2 partitions, 1st being a OEM repair partition, 2nd being your visible OS partition
  13. Open up a CLI and type "XCOPY /?" and "CHKDSK /?" that will give you a list of switches for each command.
    I use Xcopy all the time for copying directory trees, even incremental backups of folders on one computer to folders on another computer across the network.
    xcopy /s /e /d /y /c \\number3\music \\number2\music >update.txt
    CHKDSK has a switch (/X) that will unmount non-boot drives so you don't have to reboot.
  14. Anonymous
    Guest
    I need to transfer data from one drive to another
    data in 5 subfolders in e:
    are to be copied to
    5 another subfolders in f:
    So, I need to perform copy/paste
    one by one i.e. for each subfolder
    Now I want to know whether this can be performed
    via a single click on a batch file.
    Thnkx
  15. Anonymous
    Guest
    And I'm also getting problem in scanning C:
    As it in use by the operating system
    so Its suggestes to check C:
    at booting.
    When I click YES
    Then at the time of booting
    error occurs that:
    CHKDSK is not for RAW drives
    Can anybody give me a solution to this problem.
    Thnkx
  16. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    http://www.z-a-recovery.com/art-raw-filesystem.htm
    And several other posts suggest that the drive is either corrupt or failing, and needs more than Chkdsk can provide
    Read my blog here.
  17. Anonymous
    Guest
    Thnkx.
    ur great!!!
