Hey!!!
I'm getting really mad about my Compaq CRT Monitor
changing its color frequently.
from RED to BLUE to GREEN and so on...
Then I try to give it some slaps.. 8) 8)
gets OK for some time..then again that
chameleon style.
I also checked the De Gauss option on
monitor console..It works but again color changes
I have been using it for 5 years.![]()
any solution ....
Thnkx.
AnonymousGuest
Only an authorized technician is allowed to use the slap method
You are also NOT authorized to use the 6 foot drop to the floor method
It sounds like a connection inside the unit is failing - could be a poor solder joint or an oxidizing pin inside a connector.
Maybe time to replace it with a nice LCD monitor
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
The VGA cable is usually built into a CRT monitor, and not replaceable. I hope that the OP'er checked to see if the connector to the computer is loose before slapping around the monitorOriginally Posted by jagabo
AnonymousGuest
Thnkx a lot for authorization
I have checked all ports and connectors
cleaned them and plugged tightly.
but now I think, its time to buy an LCD monitor.
HELP: advice external video monitor options for color correcting
By DvdRookie in forum EditingReplies: 3Last Post: 14th Mar 2011, 15:20 -
How to calibrate LCD color monitor ?
By SingSing in forum Software PlayingReplies: 2Last Post: 8th Mar 2011, 10:24 -
Monitor suggestions for proper Color Correction
By OldMedia in forum RestorationReplies: 1Last Post: 6th May 2010, 22:32 -
TV to monitor the color adjustments
By KayAt in forum ComputerReplies: 5Last Post: 1st Jan 2009, 21:52 -
Color correction for internet distribution and how to best monitor it
By 6079 in forum EditingReplies: 1Last Post: 8th Jul 2008, 21:27
