    Jul 2008
    I've been trying to convert a QuickTime movie (MOV file) to an MPEG-2 file using "MediaCoder" with unsatisfactory results.
    I want to eventually put this movie on a DVD, using MPEG Video Wizard DVD, but the converted file loses its audio and the video plays back at higher-than-normal speeds. I've experimented with different settings with no luck.
    Is there a good tutorial out there that can explain the process of converting one type of audio/video file to another, and the best converter(s) to do so? Thanks.
    Dec 2006
    Here,where do you think?
    Are you doing some editing before authoring a DVD?..Try avidemux..If no editing is needed apps like DVDflick, ConverxtoDVD will convert/author straight to DVD..
    " Who needs Google, my wife knows everything"
    Jan 2006
    Northern Pacific SW
    What's the source of the MOV file? Digital camera?
  4. Member T-Fish's Avatar
    Apr 2009
    Switzerland
    i use this method to convert my digi-cam's .mov files to mpeg2.
    Aug 2002
    South Florida
    I use WinFF with good results.
    Aug 2005
    Smallville
    I have the same problem. I am trying to find a codec that will let me convert any quicktime.mov file to mpeg2 but so far i've tried FFdshow and it will let me open some quicktime movies in most encoders but I still am getting the odd one that doesn't open.
    https://forum.videohelp.com/topic368120.html
