  1. Hi, I have a sub file and I'd like to convert it in srt format, but I don't have the idx file; is it possible to convert the file anyway or to recover it from the sub file?
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Well, that depends... there's more than one type of .sub file. The .sub/.idx format are graphic/bitmap subs, and yes, you'd need both to work with that format of subtitles. There's also a plain text-format .sub, as well.
    How big is the .sub file? If it's relatively small, like 100k or less, try opening it in Notepad to see if you can read the contents. If you can, you should be able to convert it to .srt using Subtitle Workshop, or other tools.
  3. it's big 3.58 MB and if I open it with notepad it is not readable
  4. Then the answer to your question is 'no'.
  5. You could search the net for new subs, subscene.com has plenty.
  6. Member manusse's Avatar
    Jun 2006
    France
    Hi,
    Try SubtitleCreator although I can't guarantee it will open all the subtitles.
    Cheers
    Manusse
