Hi,
I'd like some info (general principles) regarding converting video to image sequences, particularly regarding quality. I suspect TGA is an all round ideal format? What about when converting from DVD (vob)? Is TGA overkill? Are JPGs adequate to the task? And Im correct in thinking PNGs have the same quality to JPGs (just the additional alpha channel)?
Actually, whilst Im here... Does anyone know if Premiere or vdub offer an option to encode into image sequences only designated frames, e.g. every second frame (for rotoscoping use)? Will adjusting the output framerate do the trick?
Thanks kindly!
Richard.
I've done it many times with Premiere, saving the sequence as a series of .bmp files that could be rotoscoped (or altered in other ways) using Photoshop. The series of .bmp files can thereafter be reimported into Premiere as a video clip and dropped back into the timeline. Consult your user's manual or Premiere's help file. If you want to remove frames, you simply pull out the individual .bmp files you do not want to use. (Each video frame produces its own .bmp image.)
It might be "adequate" for the OP's purpose.Originally Posted by poisondeathray
yes, bmp is just fineOriginally Posted by richardjc
I'm affraid they're notOriginally Posted by richardjc
Avoid jpeg & png by any means necessary, especially jpeg, png support the alpha chan yepOriginally Posted by richardjc
(on vdub) I don't think so but you could select a specific segment and add it to the job list and redo this operation at will then process the job(s)Originally Posted by richardjc*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
24 and 32 bit TGA, and BMP are more-or-less equivalent. Fewer programs can handle TGA, some can't handle RLE encoded (losslessly compressed) TGA. PNG output from VirtualDub is losslessly compressed.
In VirtualDub You can use the Video -> Frame Rate option to decimate the image sequence output. You can use the mark-in and mark-out tools to break a video into segments.
Problems with turning image sequences into movie files for timelapse?
By adam-tl in forum MacReplies: 26Last Post: 2nd Dec 2011, 07:05 -
DVD to DivX Conversion - Recommended File Sizes
By DakotaThrice in forum Video ConversionReplies: 3Last Post: 13th Jun 2010, 08:31 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
DV Source - Recommended format for web streaming?
By tarrickb in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 11:18 -
Recommended subtitle format for translation
By niko84 in forum SubtitleReplies: 11Last Post: 3rd Feb 2008, 19:35
