I like to use WinAVI to convert many clips into a DVD. Conversion is fast with good result.
WinAVI can produce the DVD menu automatically , but not customizable. This is what I hate most because I can not
set title, description, etc.
I like TMPGenc DVD Author to build the menu, but it takes so long to do the conversion. I can barely stand the conversion time.
Is there any smarter way to convert fast to DVD with customizable menu ?
Or is there any way to use WinAvi for conversion and use TMPGenc DVD Author to do the menu layout (while avoiding reencoding)?
Give Diko a try it uses DVD Styler to create menus. And uses HC-encoder to encode the video. And in my opinion the video quality is better than that of WinAvi.
Yes it does, there are guides that should give details on doing this. I don't recall off the top of my head its been a few years since i used it. I now encode everything to mkv h264/ac3 and store on my media center after backing up to removable media.
Look at SVCD2DVD.
Customized fonts. Help me?
By NeroLi8gerzid in forum SubtitleReplies: 15Last Post: 4th Oct 2011, 00:09 -
Customized Version of FFMPEG for Professional Usage
By Soopafresh in forum EditingReplies: 28Last Post: 28th May 2011, 10:07 -
Customized DVD (and possibly Blu-Ray) Menu Templates
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 16:02 -
A/V Linux 1.0: A Customized "Snapshot" for Audio and Video Enthus
By GMaq in forum LinuxReplies: 0Last Post: 10th Jan 2009, 21:43 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20
