I'm on a mission, and I need me a solution...
Is there any program available what can properly extract a full audio stream from a Flash ".swf" file?
Not .fla, but .swf?
So far, the closest I can get to SWF --> AVI conversion is a video-only stream. I can't get the audio to convert.
I'd appreciate any help. These are files I made over a year ago, the source .fla files have long since been deleted (accidentally, of course)![]()
I made the .swf files, then into .exe's. The most I can convert back is to .swf again, but now I'm stuck and need a utility to extract the audio.
Thanks in advance!
It never rains, but it pours..
I just answered this on another thread-
http://www.vcdhelp.com/phpBB/viewtopic.php?p=206009#206009
Total Recorder. It's probably listed in the tools links to the left.
Good luck.
Scott -
Thanks for making the rounds! (That was me in the other thread, to...)
I'll give Total Recorder a try... -
Total Recorder works absolutely wonderfully. I was even able to change settings to not interfere with V-Dib captures (which it started doing, but at least had an option to start).
With a little work in the re-synch area, I now have the perfect SWF --> video/audio conversion!
DTS-HD Master Audio Extraction from Tsmuxer
By m1ke486837 in forum Blu-ray RippingReplies: 0Last Post: 5th Jan 2011, 19:29 -
MP4 audio extraction (ripping the 5.1)?
By takearushfan in forum AudioReplies: 15Last Post: 13th Sep 2010, 08:12 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 15:56 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 19:17 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 04:05
