JVC will filter the VHS more, others will not.Originally Posted by mw01908
H.264 is complicated. Without writing up a big diatribe, I don't think that's a route you want to mess with.
Results 31 to 33 of 33
It would have to be a spectacularly noisy source to give visible pixellation with DV. Even then, it should go slightly soft, rather than pixellated.Originally Posted by mw01908
Remember DV encodes each image separately, a bit like a series of 125kB 720x576 JPEGs. Even a screen-full of random noise can be encoded OK at that data rate.
The "problem" with MPEG-2 is that it looks for similarities between frames, and only codes the differences. Random noise is completely different on each frame, so with lots of noise MPEG-2 can be less efficient than DV! (Unless you force MPEG-2 to use all I-frames, which makes it similar to DV and M-JPEG).
The real problem of course is that you probably want this to end up on DVD, and you'll have to do some filtering to make it easier to encode.
Cheers,
David. -
man this is my exact work flow as well. i use a Panasonic HS-950. Then into an ACE tbc (awsome) then into a Canopus ADVC100. Then i use Vegas to run the Neatvideo plugin (incredible ) then i convert to H264 (i use the mainconcept standalone convertor prog as its the only H264 that i have properly tested with interlaced video that actually makes interlaced H264 files). Be careful most H264 convertors (Handbrake etc) will break the interlacing and drop half of your frames. ie your video will look jerky.
my transfers are generally better than the original. So good i throw away the VHS tape. which believe me, i would not generally do if there was any doubt in my mind that it wasnt perfect!
i think this workflow is very similar to many others...its a tried and tested method that just works!
re: mpeg2 (DVD) vs H264 from my extensive testing, H264 kicks mpg2's ass. Run H264 with a high bitrate of say 3500 and use the "High" profile and it creams any mpeg2 encode of the same VHS tape on 8000 bittrate. For a still picture, you wont see a difference. For a lot of good quality digital capture sources, you wont see a difference in quality, other than a smaller file size for H264. But add some VHS noise and some long swaying grass that is being panned across with the camera and watch mpeg2 just fall apart at the seams, even at 8000 bitrate. a H264 encode just looks "effortless" and the mpg2 encode just looks like its struggling, no matter how you tweak it. Just an older, less optimized algorithm vs a far more efficient and superior one. if mpg2 could go up to , say 16,000 bitrate then it would probably approach H264 on 3500. but the mpg2 file would be probably 20 gig size and the H264 would probably be 1 gig. hehe
noise in a picture (dirty VHS tape noise) and how well it is encoded is what really separates the men from the boys of encoding software.
Cheers,
BlackoutLast edited by Blackout; 15th Sep 2011 at 04:50.
Transferring multiple VHS tapes at once...
By robin_west in forum Capturing and VCRReplies: 10Last Post: 29th Dec 2011, 06:16 -
Advice for transferring many MANY VHS tapes to external HDDs
By ryanwayne in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2009, 23:21 -
Transferring Old mini DV Tapes
By femtonitpicker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Apr 2009, 20:41 -
transferring old vhs tapes to computer for editing and burning to dvd
By michael109 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2008, 12:00 -
Problems capturing analog video from VHS tapes
By jdwmba in forum Capturing and VCRReplies: 8Last Post: 15th Mar 2008, 18:52
