I normally use Subtitle Creator to convert srt to sub/idx, but I have an avi with srt that the subtitles for some reason are off by a few seconds at the end of the movie when converted to sub/idx using Subtitle Creator. The original avi srt subtitles are in sync. In Subtitle Creator I choose Ntsc because Gspot showed 24 something framerate. Then I tried the software txt2vobsub to convert the srt to sub/idx and that worked. The sub/idx subtitles were in sync. However, I don't like that when one subtitle line is shown, the vertical position is higher--on the first line. (When 2 lines are shown, the position is correct.) So I would like to know if there is another software I can try to convert srt to sub/idx.
If you wish/need to have full control and no limitations,
the best approach is:
--- convert .srt to .ssa ;
--- convert .ssa to .son with MaestroSBT ;
--- convert .son to .sub with Son2VobSub.
Txt2VobSub works, but it still needs the obsolete codepage nonsense,
and cannot go beyond two lines of text per picture.
Originally Posted by Midzuki
What I'd like to know is why it's so important to have the subs in IDX/SUB format. And even if for some good reason they have to be in that format, more important, I think, would be to figure out why the timings get messed up in the SRT->VobSub conversion and then fix it. My guess is that he's not doing it right. For example, this:
Originally Posted by jimdagys -
Subtitle Creator under "Format" allows you to only choose pal or ntsc. I just remember Gspot for this particular avi said 24 something framerate, so I chose ntsc in Subtitle Creator. Choosing the wrong standard (pal/ntsc) in Subtitle Creator in my mind certainly shouldn't cause the subtitles to get off by only a few seconds by the end of the movie. I think if I choose the wrong standard (pal/ntsc) in Subtitle Creator, this will cause the subtitle position to be incorrect, or cause the subtitles to be off by several minutes.
As far as why I want sub/idx, that is because these avis are shown on a computer with large screen TV. For technology reasons, they must be on one cd (not dvd) and I want the subtitles to appear bigger and brighter without the movie operator to make even 1 click on the computer (necessary) or change any parameter in the computer. With sub/idx, I can easily increase subtitle size by changing some numbers in the idx and also easily change subtitle color with Subtitle Creator (and when playing with Media Player Classic and some other software players. -
25 vs 23.976 fps would cause a ~1.6 minute sync error by the end of a 90 minute movie. 25 vs 29.97 would be about 18 minute error at the end of a 90 minute movie. -
[I think if I choose the wrong standard (pal/ntsc) in Subtitle Creator, this will cause the subtitle position to be incorrect, or cause the subtitles to be off by several minutes.
So they don't have to be IDX/SUB, just some format in which you can set the styles. If you go the SSA route, an SRT can be instantly converted to SSA using SubResynch (included with VobSub). I use SubStation Alpha to set the Styles. Once set up the way you like (font, size, outline, color, position, etc), just opening and then saving them will make them the way you like. I think Aegisub and other programs can do the same but, as I said, I use SubStation Alpha. -
If, by the end (of a 2 hour movie), they're 7 seconds early (as I suspect), then in the framerate synchronization section of SubtitleCreator you want to convert those IDX/SUB files from 30.00->29.97. If, by the end they're playing 7 seconds late, then 29.97->30.00.
How do I convert DVD or sub/idx to text srt subtitles?
By Baldrick in forum SubtitleReplies: 70Last Post: 28th Mar 2016, 20:37 -
Convert batches of SRT to SUB+IDX - smooth bitmaps
By rotven in forum SubtitleReplies: 5Last Post: 29th May 2015, 13:15 -
How to convert IDx/Sub to Srt w/o typing a manuscript
By FireWalker in forum User guidesReplies: 16Last Post: 8th Jul 2013, 12:30 -
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 04:23 -
how to convert an .idx subtitle to a .srt file??
By vinayak1986 in forum SubtitleReplies: 1Last Post: 9th Sep 2007, 11:53
