    May 2009
    Hi all
    I'm trying to overlay a title to the main video on a DVD. I've ripped the contents to my hard drive and done the title but when i encode the movie it comes out smaller in filesize and when I try to burn the disc I get an error and the movie on the disc has no sound.
    I've used dvd decrypter to rip (the disc not encryted anyway), adobe premiere pro cs4 to edit and Nero to burn.
    I know its probably to do with the IFO's and the altered file size but I don't want to re author the whole DVD.
    Please help
    Many thanks in advance
    Jon
    Apr 2004
    Miskatonic U
    You need to use a bitrate calculator to determine the correct bitrate settings for your encoder to ensure you get the right file size. You then need to author the file you put from Premiere as a menuless movie only structure of VOB files, and use VOBBlanker to replace the movie in the original disc with the new version you have created.
    You should then write the results to a blank DVD with Imgburn
    Read my blog here.
