I'd like to call upon the experience of those veterans to this site for some assistance. In brief, here is what I'm looking for: I want to be able to record & watch video from my Motorola DCT2500 set top digital cable box (not HD). I also want the ability to send audio/video from my PC back to my TV via s-video and standard RCA for audio. The third concern I have is in regards to video processing ability. What I mean by that is, when I finish a production in Sony Vegas Pro and want to render it to a specified format, do the above mentioned card types handle the processing? Lastly, is there ever a concern about having an adequate power supply?
For reference my PC specs are:
OS: Windows 7 Home Premium (x64)
HP-Pavilion FK575AA-ABA a6658f
System Serial Number: n/a
Enclosure Type: Desktop
2.40 gigahertz Intel Core2 Quad Q6600
64 kilobyte primary memory cache
4096 kilobyte secondary memory cache
Board: PEGATRON CORPORATION Benicia 1.01
Bus Clock: 1066 megahertz
BIOS: American Megatrends Inc. 5.30 09/05/2008
Drives: 640.13 Gigabytes Usable Hard Drive Capacity
433.56 Gigabytes Hard Drive Free Space
Memory Modules: 6134 Megabytes Installed Memory
Slot 'DIMM0' has 2048 MB
Slot 'DIMM1' has 1024 MB
Slot 'DIMM2' has 2048 MB
Slot 'DIMM3' has 1024 MB
Any assistance with this would be appreciated. I find the number of choices available on the internet to be quite over whelming.
Life is like a game of poker. If you can't spot the sucker after a few minutes...then you ARE the sucker. -
*bump*
#3 No, they just capture and/or encode video.
Usually for a cable box you just capture the S-Video and audio from the box. You don't even need a tuner.
Capture devices are availabel to DV (ideal for Vegas), to MPeg2 (also works) or AVC (less friendly to editing).
The cable box feeds the TV and your PC display card also feeds the TV to an Aux input (S-Video+Audio). If the TV is HD there are better ways to connect.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Using S-Video To Capture Into Hauppauge 1600 TV Tuner Card
By waldodiodio in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2010, 17:49 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 09:52 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
