Results 1 to 30 of 72
You start by changing the topic subject so it better describes the topic.
1. Read the included docs, especially the DGDecodeQuickStart.html.
2. If you have to deinterlace, use a better deinterlacer. Yadif is, in my opinion, the fastest good deinterlacer. If quality and not encoding time is your main concern, then nothing beats TempGaussMC.
3. By IVTCing it.
4. TFM().TDecimate()
is one way. They're part of the TIVTC.dll.
Any questions for me? -
Do I use Yadiff like this Yadif(), or Yadif(0,5,0), or Yadif(0,5,1)? Thank you for the info.
How do I change my subject title. -
You use it as explained in the included doc. For basic TFF deinterlacing:
Yadif(Mode=0,Order=1) -
Will someone edit the subject to something more apporiate? Please edit it ASAP per my request. I know moderators are watching.
Originally Posted by rocky12
Just edit your first post and change the topic lineThere's not much to do but then I can't do much anyway. -
I still don't understand. I seen that already. Why a tutorial? I need to know how to remove the language screen.
http://www.digital-digest.com/~blutach/Jump2PGC/Jump2PGC_guide.html
However, there's a good chance I've misunderstood you, because you're not making any sense. Why are you opening menus in DGIndex anyway? -
My problem was I had a VTS menu. The preview showed interlaced. Saving the .d2v showed progressive. Which should I go by? Thank you for your help and time.
Originally Posted by manono -
If your main objective is to bypass the language Menu why worry if the DVD is progressive or interlaced?
So i'm assuming that you have ripped the DVD an have the unencrypted files stored on your hard drive. What is the end result that you want to accomplish? -
Doing a preview in DGIndex it showed interlaced. Saving the .d2v it said progressive. -
I am trying to upload .d2v. I don't know how to save M2V.
dgindex.d2v -
Here's how you save the M2V from DGIndex. Open a VOB and use the [ and ] buttons to mark off a small area and then File->Save Project and Demux Video. Then, in addition to the D2V project file and the audio for that small section, it'll also give you the M2V.
Never mind, though. That D2V is quite clear about what you have. The entire movie is pure film with an opening interlaced (and probably hard telecined) short section of either a lot of black frames or maybe a short logo. One way to handle it would be to set the Field Operation as Honor Pulldown Flags, make the D2V, and then IVTC it like so:
TFM(D2V="C:\Path\To\Movie.d2v")
TDecimate()
Adjust for the names and path. Another way to handle it (and somewhat faster, as far as the encoding would go) would be to set the field operation to Forced Film and make a 23.976fps D2V. Then check carefully the opening frames to make sure there's no interlacing. The first way is slower but more guaranteed. The 2nd way is faster but a bit riskier, but should be OK if you check the opening few hundred frames or so for interlacing - up until the actual movie begins.
Can I just deinterlace the source? -
Do I need to deinterlace with yadif?
I read it. Is DeBlock, and MSharpen, or anything like that necessary?
Audio questions to prevent synch. What is the sound file has a negative number? I put the negative in the interleaving? Should I change 500 to 0, or keep 500.
What if the movie has 3 audio tracks? Which one should be used? -
If DgIndex indicates a negative audio skew enter a negative audio skew in VirtualDub. If you want multiple audio tracks use VirtualDubMod. If you want only one, figure out which one is the one you want (listen to them with a media player) and use it.
Jagabo, or someone.
Can someone tell me if I change the default 500 to 0, or leave it at 500? -
Question #1 - Is English your primary language?
Question #2 - Are you over the age of 14?
Statement - The GUIDES section is there for people such as yourself. Read some, then read some more. You are asking questions which indicate a deep and vast lack of understanding of what you are working with. You need to comprehend the basic terms and structure in order for the answers and help you are getting to make sense to you.
It would also be helpful if you would give precise and clear answers to questions directed to you. -
Jagabo,
Just ignore the post reply. Will you help me please? Or should I say plz to piss him off?
Originally Posted by jagabo
How To deinterlace IVTC ntsc promo only music video
By jamespoo in forum Video ConversionReplies: 14Last Post: 24th Mar 2011, 16:12 -
Question Re IVTC, DGIndex & NTSC Source
By onesikgypo in forum Video ConversionReplies: 7Last Post: 18th Aug 2009, 03:58 -
Can't properly DeInterlace or IVTC
By igoryonya in forum Video ConversionReplies: 46Last Post: 4th Mar 2009, 17:47 -
DGIndex Force Film vs IVTC
By alcOre in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2009, 02:25 -
dgindex what to choose
By cd090580 in forum Video ConversionReplies: 1Last Post: 29th Feb 2008, 17:33
