Hi All,
I'm trying to convert a .mov (have mp4 version too) to an .flv via ffmpegX.
i've installed all necessary library's and the special flv item.
When I choose to convert to flv, the process takes less than a second to indicate 'finished'. Needless to say I end up with a blank movie. (for the record: I have complete authority over the clip)
IN attachment an image with all starting details.
The Process info shows:
I presume that line tells me there is a mismatch, but I do not have a clue what to do about that.Code:FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Codec type mismatch for mapping #0.0 -> #0.0
Any hints in how to proceed from here are grately appreciated.
Regards,
psil_
	ouch I'm sorry,
 my apologies for littering the forum.
 I did google on 'FFmpegX flv problem osx', but I should have searched on 'Codec type mismatch for mapping #0.0 -> #0.0' before calling for help.
 If anyone has the same problem, fix it easily as such:
 go to the audio tab and check 'invert mapping'.
 regards,
 psil_
  x264 log fileBy txporter in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 16:40
  FAVC log fileBy marioval in forum Authoring (DVD)Replies: 3Last Post: 31st Jan 2008, 07:17
  Evaluating a group of video filesBy wallywalters in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2007, 18:25
  DVDAuthorGUI Unknown error - log included *SOLVED*By ChibiTomo in forum Authoring (DVD)Replies: 2Last Post: 9th Oct 2007, 14:18
  ffmpegX Progress logBy exekutive in forum ffmpegX general discussionReplies: 5Last Post: 20th Jun 2007, 16:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
