Would appreciate your help
I had a friend that was on a newscast. I happened to have my tivo on and captured it to my computer through the Tivotogo software on my computer. I then converted it to an mpg with directshow dump. I can play the file just fine in windows media player. I then drop it into adobe premiere cs3 and everytime I do it crashes.
I can see that the video properties are 480x480 29.97 and the audio is listed as 48000 hz compressed stereo.
Any other suggestions of what I can do to clean this up so that adobe won't crash.
Looking for freeware software as I don't plan on doing this often if possible.
Premiere isn't a native mpg editor, so it isn't the best tool for this job. You haven't said what you actually want to do with the video, so it is difficult to suggest alternatives. If you have to use Premiere then you may have to convert it to a more edit friendly (or Premiere friendly) format. DV would be the first choice, but you would have to resize or add borders to get to DV resolution.
Otherwise consider something like AVI Demux for editing.Read my blog here.
I skipped Premiere CS3, but CS4 seems to work fine with MPEG2 content.
The other possiblity as your "dump" didn't generate a proper stream with headers intact. Videoredo is supposed to work with Tivo streams to make a compliant MPEG2 stream. Maybe you could use the trial (I don't think it has any limitations) since you are doing this once. -
My plan was to edit the extra stuff around my friend out so all I was left was the newspiece about her.
I was going to drop it into DVDlab Pro and author her a short DVD - Nothing fancy with titles just something she could throw in her DVD player. -
For simple cuts, avidemux as suggested earlier should work (and free), provided your streams have no errors from the dump. Videoredo is probably the among the best MPEG2 editors for cutting, because it is frame accurate and re-encodes the few frames around the cut site if not on an keyframe. It also has a "quickstream fix" which often gets rid of MPEG2 issues.
Also, 480x480 isn't DVD compliant, you can't drop that into DVDLab Pro -
VideoReDo would be my suggestion here too. Author to an SVCD, or re-encode to DVD compliant 720x480 specs.
I installed Avidemux and when I play the file there it seems that the audio is off from the video.
I found that when I put it in premiere it was during the "conforming" step that it crashed would that add any clues?
Its wierd that in the player it is in sync but in the avidemux it is off.
slow editing on cs4 premiere
By maplewood in forum EditingReplies: 22Last Post: 2nd Feb 2012, 13:41 -
Editing AVCHD video in Premiere CS4
By helionfilm in forum EditingReplies: 6Last Post: 22nd Apr 2011, 10:57 -
Adobe Premiere and editing of long movies...
By arminio in forum EditingReplies: 6Last Post: 25th Feb 2008, 19:07 -
Help with editing in Premiere with 1080i 24P
By Martig in forum EditingReplies: 3Last Post: 3rd Feb 2008, 21:27 -
Editing ac3 Audio in Premiere
By tSu in forum EditingReplies: 5Last Post: 10th Nov 2007, 21:32
