AutoGK CTRL F9 DOES NOT WORK no matter how many times I press the button it fails to load up. Do you guys know of any program that could be stopping it from working. I removed and reinstall the program and not matter how many times I press it I cannot access the hidden options in Auto I used to be able to access the options but now nothing happens when I press Crtl-F9..
I do however have the kazaa lite codecs installed and that still does not allow me to load the hidden options. I uninstalled the version of k-lite and I still get cant get in. Does anyone have any ideals.
As of right now I'm going to use your uninstaller and remove the auto gk then manually go into the registry and delete the keys my self wish me luck.
Results 1 to 9 of 9
Yes I have tried serveral different videos.
After the uninstall/install I still don't have any luck Man I'm very stuck right about now. -
Installing a codec pack wouldn't help with the problem, anyway.
Do you have any keyboard shortcuts set to Ctrl-F9? On one system, I did, and that caused absolutely nothing to happen if I pressed it in AutoGK - the hidden options wouldn't come up, and neither would whatever program I had set to open if I pressed Ctrl-F9. Try Ctrl-F9 when AutoGK isn't running/open, and see if any other program pops up.If cameras add ten pounds, why would people want to eat them? -
What do you mean by short cuts I don't have anything out of the ordinary. Not that i know of. Hell I even tried using the on screen keyboard and I still cant get in. I'm about to do a fresh intstall if this fails.
Crtl F9 alone does not do a thing we program not loaded program not loaded
I don't know why you can't access it, but they're called the "Hidden Options" for a reason. Is there any particular reason you have to get in there - anything you want to change?
Never mind what I need to access the hidden options for. I just need to get into them. I can access the options on another pc but for some strange reason I cannot on this pc I don't know whats going on. Some thing is blocking me from getting in I'll figure it out shortly. If any of you guys have any ideals please feel free to share them thanks in advance.
I had this problem too...
I solved that problem by simply change my fancy keyboard to a standard one. It worked right away !
With autogk no subtitle load window after clicking ctrl-f8
By 3l8x in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2010, 17:19 -
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 23:38 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 20:37 -
How does AutoGK work for making SVS to avi files?
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 15:08 -
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 15:04
