I have the 7 Ultra Edition and have only used to burn audio and data CDs. I never used it for anything else but my son had to do a school project using our Mini-DV camcorder. We attempted to use Nero but we didn't have a video capture device so we weren't able to transfer to my PC to load and edit with this software.
I have researched capture devices because I want to also transfer old family VHS tapes to PC to edit, etc. The thing is from what I have found so far they all come with their own software. I am looking for something that will work with Nero 7 without having to install another software.
Please recommend capture devices from VHS to PC that works with Nero 7 Ultra.
Thanks so much.
minidv cam tapes should be transferred to the computer over firewire(ieee1394/ilink). the program to use is winDV and it is free. click on it's name and download it.
if you don't have a firewire port it would be best to buy an add in card, they are fairly cheap. then if the cam does analog to digital passthrough you can use it to capture analog video like vhs tapes. -
Thanks much for the reply. We were able to transfer via firewire and download and edit by Windows Movie Maker.
As for my VHS tapes I will have to go from my VHS player via capture device, connect to PC, and hopefully be able to use Nero. Do you know of any capture devices that will work with Nero or do you think I will have to purchase a capture card? Roxio makes a nice capture device but I am wondering if I have to use their software.
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 16:56 -
Help with streaming from an ultra sound device.
By richared1979 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Oct 2011, 03:02 -
Need recommendation for portable device.
By therock003 in forum Portable VideoReplies: 8Last Post: 20th Apr 2009, 13:59 -
Plextor M402U - Capture Device not recognised (WINDVD and Nero)
By phantomwalker in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2008, 21:52 -
Need Capture Device recommendation advice!
By unclekracker in forum Capturing and VCRReplies: 4Last Post: 2nd Apr 2008, 12:54
