A question from a newbie:
I had read that AVI was a compressed format suitable for ipod and ipod-like devices. Just as an experiment, I took a WMV file (seven minute slide show with music) and converted it to AVI: It was 3 gb! That compares to 300 mb as a highest quality MPEG.
Even saving it at lowest quality, it would have been hundreds of megs.
Did I misunderstand? What am I missing here?
Thanks,
Paul
avi is just a video container and can contain different video and audio codecs. So what video and audio codec did you use? It sounds like uncompressed video and that is HUGE. If you use a compression like xvid you can get a small size and you can also set the bitrate and you can get whatever file size you like.
But for ipod is probably mp4 with h264 video and aac audio the best solution. Use for example handbrake,xvid4psp or iPodME to convert(ALL FREE TOOLS). -
Thanks very much! As I said, I'm a newbie.
I had gone into the advanced window and saw a variety of codecs, but didn't know which to change it to. Come to think of it, when I got my classic ipod 60gb 2 1/2 years ago, I downloaded a program to convert videos. But I never used the ipod for videos, given the small b&w screen. I'll go back and look for that program, and check out the programs you mention. I'll also play around with SmartDVD to see if what codecs it has.
Question: What bitrate would you recommend for an current gen ipod? I'm interested in all this now because I'm getting one.
Thanks again,
Paul -
Last evening, downloaded the xvid codec, and obviously was able to convert at any size (quality) I wanted. I'm going to try your suggested programs you mention.
Thanks again,
Paul
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
help converting WMV to AVI
By user943 in forum Video ConversionReplies: 5Last Post: 11th Nov 2008, 11:39 -
converting wmv to avi
By evile1690 in forum Video ConversionReplies: 1Last Post: 9th Jan 2008, 05:15 -
CONVERTING FROM AVI TO WMV or RM
By sunsound in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 04:17 -
Help converting .avi into .wmv
By Theros in forum Video ConversionReplies: 13Last Post: 5th May 2007, 19:10
