I'm thinking of buying the above mentioned fan to mount above the CPU and heatsink and was hoping some members have this fan mounted above the CPU and can advise how it is performing.
Unknown to me but it is solid copper and the fan upon it is 60mm. I intend to use an 80-60mm reduction adaptor and mount the 80mm fan mentioned on top, I'm reasonably sure there will be members using that fan and just wanted some input about its performance.
Then you should post at computer forums like extremesystems and overclockers and overclock.net. They have cooling forums that could probably answer you question regarding that fan.
CPU Fan has failed please advise
By V Bot in forum ComputerReplies: 21Last Post: 23rd May 2010, 15:47 -
New cpu heatsink/fan for phenom II 940
By johns0 in forum ComputerReplies: 11Last Post: 3rd Jul 2009, 19:59 -
INTEL 478 socket - 775 socket heatsink/fan
By blinky88 in forum ComputerReplies: 7Last Post: 7th May 2009, 10:38 -
ATX power with fan on top ?
By SingSing in forum ComputerReplies: 9Last Post: 16th Nov 2008, 20:31 -
what heatsink/fan would fit?
By gooberguy in forum ComputerReplies: 5Last Post: 25th May 2008, 17:07
