I'm converting from a 20,000 kbps .wmv9 clip to mpeg4 and I was just wondering what bitrate I should encode at to be as close to lossless as possible. Thanks.
Harrison
What MPEG4? Layer 2 (Divx/Xvid) or layer 10 (h.264/AVC)? Guessing the latter:
Bitrate? Impossible to say. Use CRF encoding and select the quality you want (lower quantizer -> higher quality). Each frame will get the bitrate it needs to deliver that quality.
x264 has a true lossless mode. Your files will get very big though.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
