Hello all,
I have 20 gigs of .TS files (5 files of 4 gigs each) and I'd like to merge them all and compress into an MKV file, I have looked in the convert guide but I found nothing to nsuit hat I need.
Handbrake won't read my .ts files (VLC plays them fine) so I'm a bit lost...
Maybe I should try to merge the ts files firstly and then convert them ?
thanks for the help
There are the details, it's in french but I'm sure it'll be usable
Thnanks
Format : MPEG-TS
Taille du fichier : 4,31 Gio
Durée : 35mn 19s
Débit global moyen : 17,5 Mb/s
Vidéo
ID de menu : 1 (0x1)
Format : AVC
Profil du format : Main@L4.0
Paramètres du format, CABAC : Oui
Paramètres du format, RefFrames : 2 images
Durée : 35mn 19s
Débit : 15,5 Mb/s
Largeur : 1 920 pixels
Hauteur : 1 088 pixels
Format à l'écran : 16/9
Images par seconde : 25,000 Im/s
Résolution : 24 bits
Colorimétrie : 4:2:0
Type d'image : Progressif
Bits/(Pixel*Image) : 0.298
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Type de débit : Constant
Débit : 768 Kbps
Canaux : 6 canaux
Position des cannaux : Front: L C R, Surround: L R, LFE
Echantillonnage : 48,0 KHz
Delai par rapport Vidéo : 43ms
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Débit : 448 Kbps
Canaux : 6 canaux
Delai par rapport Vidéo : 214ms -
Do you have haali media splitter and ffdshow (or other h.264 decoder) installed? If not, install them and try handbrake again or any of the other programs listed by Baldrick
You can merge them prior to re-encoding by using tsmuxer -
Ok, done (70 minutes !)
Now handbrake sees the file, what settings should i use to get a MKV with the best quality/size possible ?
It's a 1080p so I want to keeop it clean but reducing the size from 22G and keeping it good should be possible, no ?
I have 2 sound streams DTS and AC3, both in 5.1, do i need to keep both, if I keep only 1 which is the "best" to keep ?
Thanks a lot for the help -
Try use constant quality encoding mode if you don't need an exact size or else try shrink it to around 4-8GB with 2-pass encoding. I would keep the dts sound if you have a system that supports it then.
Ok, thanks for the tips, what's a "good compromise" for the constant quality setting ? I don't mind having a file that's 10-12 gigs compared to 4-6 gigs but the quality must be visible, otherwise it's not useful.
I'll be playing this with a dvico 6500A on a sony HW-10 through a yamaha RXV-1900 so i think i have quite a decent system...
Final question about the sound, if I keep the DTS track I still have to choose an encoding method from AAC, MP3, AC3 and Vorbis, I think that MP3 and AC3 are out (MP3 will not be good enough and AC3 would need the AC3 track and not the DTS one) but which do I choose ?
Handbrake should/could have a bit more setting explanation
instead on relying on Baldrick !!
THANKS AGAIN !!!
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
Help a Newb streamline things a bit. MKV AAC to MKV AC3.
By akinakin in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2011, 04:07 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 01:45
