I've been using the Amoisonic V2000MKII digital recorder
to capture video to VCD & SVCD. The results are usually very good, but the latest results are almost amazing.
I was playing a region 2 DVD on region-free Raite player
and capturing to MPEG1 VCD. The result floors me because there is NO visible artifacting - NONE! I have done many VCD's before and there is always a small amoung of pixellation visible. Usually I'm going from VHS to VCD, and I use SVCD to capture DVD video. This is the first try at DVD to VCD, and the quality looks just about as good as the MPEG2 on a SVCD. I wonder if the PAL format of the DVD video signal has anything to do with this?
well thats good for you...but only lamers capture a dvd to vcd or svcd.....or plain lazy people...no need to capture it and pray it comes out good when u could just rip it properly with the many guides and tools on the net...not to mention you would have true 23fps with pulldown which cant be done by capturing......idiots...
plg-tae:
you seem to have a lot of angst in you.
just because other people have faster, easier ways of making VCDs don't make them 'lamers'.
if anything, people like you are lame.
yumagah:
good for you man. perhaps you can upload a sample so we can see for ourselves?Cheers~
JCPicache -
Hey you have the right idea about capturing, I use the hauppage PVR to capture to SVCD all the time on a 2 hour movie I can have it done and on 2 SVCD's in about 30minutes after the movie is captured including all the printing done, crap this rip your dvd's off will take you 2-4 times longer, if you even have a fast computer. anyone who spends all that time to rip a DVD to a VCD or SVCD has way to much time on their hands.
I could see a rip if you were going from DVD to DVD, but the results to VCD or SVCD will not be noticable, unless you are using a cheapo DVD player instead of a higher end model that will have either a 27mhz, 10 bit D/A convertor or the brand new 54mhz, 10 bit D/A convertors.
Also try capturing your VCD's at the higher 2520 bitrate, I get no macro blocks at all at that bitrate. -
I'd be glad to share some clips but I don't know where I can post
them. My home website doesn't allow MPEG files. I can share
them on Morpheus if anyone want to use that. Does anyone
know a free site provider that allows MPEG's ? -
plg-tae
Member
Posted: Feb 18 22:32
This dude is a lamer. May be this person dont want to wait the 8-10 hours to reencode, and that is if they have a fast 1.2 gig on up system, otherwise it could take up to 30 hrs, as in a Celeron 400.
Dumbass ;)
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
