Is there any way to know the number of segments a title will be divided into for encoding in DVD Rebuilder? I like that it re-encodes this way but I would like to know how it decides to divide up the videos. It creates one d2v file but it encodes each large title as several m2v files which it stitches back together in the rebuilding phase (it seems to process stills separately - stills in galleries that are actually several static menu pages rather than a video file).
I hadn't thought of that.
If this is too much of a tangent, I'll move it to another thread but: HCEncGUI allows you to set chapter marks or import them. Does it then encode the video in segments? -
No, it just makes sure that the frames designated as chapter points are I-frames.Originally Posted by ecc"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Oh, thanks. I always found it annoying that the DVD Authoring programs would move my chapter points to the nearest I-frame. I'll try setting them before encoding.
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20 -
Mixing 4:3 & 16:9 Segments Onto One DVD
By DeathStalker77 in forum Authoring (DVD)Replies: 2Last Post: 18th May 2010, 20:21 -
Copying Segments From DVD`s Advise.
By opopopo in forum EditingReplies: 9Last Post: 9th Jan 2010, 06:41 -
DVD Rip segments ---> FLV
By statman24 in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 10:14 -
Organize a DVD into segments for MP4 encoding
By Trac in forum User guidesReplies: 0Last Post: 24th Jul 2007, 02:38
