Hi guys,
could somehow please tell me how to capture svcds with aiw 128 pro?
i followed this tut for vcds (http://www.vcdhelp.com/ATI_AIW_Guide.htm)
and i'm happy with it.
i wonder if i just change the width & height or is there anything other that needs to be set for it to work properly
any help would be appreciated
KocurLopkar
The difference between VCD and SVCD is more than the resolution.
For example:
SVCD is MPEG2, VCD is MPEG1.
SVCD is interlaced, VCD is not.
SVCD has a higher bit rate than VCD.
If you are using MMC 7.5 (recommended) then try
[http://stinky.dosrules.com/] where there are some SVCD presets.
If are using earlier MMC, then you will have to create your own preset with appropriate settings. Unfortunately I don't have my own settings to hand at the moment. -
on MMC 7.1 , here what i did
(AiW-radeon)
create new profile
mpeg2
480x480
2.39 mbit/rate
100% quality
this is the closest you can get , but not 100% compliant
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 10:52 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13
