    Feb 2008
    Portugal
    Hello everyone.
    I have a phisical hard disc of 120 GB. I created two partitions D: and K: 60 GB each one.
    But now, I formatted them and I want to join them in one of 120 GB and call it D:.
    How can I do that?
    Thank you for your help.
    Cheers.
  2. use fdisk and delete both partitions. then create one new one, then format again.
    Feb 2008
    Portugal
    In Start -> Execute I used fdisk D: but it didn't find that command.
  4. i run it off an old dos floppy disc.
    if you don't have one then you should be able to do it from control panel/administrative tools/computer management/disk management. right click on the partitions in the lower right panel and select delete.
    Feb 2008
    Portugal
    Hello, Minidv2dvd.
    Thank you. I succeeded with your help.
    Cheers.
  6. you're welcome! have a good one.
