Results 1 to 10 of 10
    May 2009
    Hey everyone, I'm having a lot of trouble transferring files from my camcorder to my computer.
    I have a Panasonic VDR-D230. It records onto 1.4GB DVD-Rs. However, when I put the DVD-R into my computer, it doesn't recognize it. Also, when I keep the DVD-R in the camcorder and connect it to the computer via USB, it still won't recognize it.
    Is there anything I can do to correct this?
    Thanks in advance for your help!
  2. sounds like you haven't finalized the dvdr. after you do it should be accessible to windows.
    Sep 2006
    R T F M....................
    Windows does NOT recognize a USB CAM........ Unless you have some special software...
    You need to finalize the disk...
    Do they play on a regular TV type dvd player???
    May 2009
    No. However, they will play when you use the A/V cables to connect the camcorder (with the disk still in it) to the TV.
    Any suggestions for software that will allow Windows to recognize the camcorder?
  5. did you finalize the disc before trying it in the computer?
    the software would have come with the cam if there is any.
    May 2009
    Yes, the disk was finalized.
    Are there any aftermarket software options to allow my computer to read the disc?
    Sep 2007
    Philippines
    good day....you mentioned "when I put the DVD-R into my computer" right? if i may ask, do you have a dvd writer or dvdrom in your pc?...where exactly did you put the finalized disc as you said in your pc?
    May 2009
    My computer has a dvdrom.
    May 2009
    you could try isobuster or cdroller.
    Thanks.
