You can go to my site for more information about this...
Antonio S.
http://www.antonio.owns.it
Results 31 to 35 of 35
Originally Posted by mjwhite
I think the elapsed timer counts bits. It is expecting a standard, constant VCD bit stream. Instead it is getting a faster and variable SVCD bit stream. Maybe I'm all wrong on this but seems plausible to me.
Are you not getting any audio sync problems? Some SVCD's cponvert fine for me but others have an audio delay that I have to fuss with to fix. -
Hi, I'm having some real problems with this method. I followed Elder's directions precisely, and burned fine. When i multiplexed it, i selected "MPEG-1 Video CD", and burned with NERO as a non-standard VCD. However, when I play it on my SONY DVP-C600D, the I can only see half the picture! It seems the entire screen moved down halfway and over a bit, letting me see only the top of the movie on the bottom half on my TV screen.
Can someone PLEASE help me?? I would really like to play SVCD's in my player. Any input will be greatly appreciated.
Octavian -
Oct,
There are no gaurentees.
I've done this method, and it plays great on my Sony NS-400D.
Then, I take the same CD to work, slip it into the Panasonic (forget model) that can hold 3 CD's, and was a lot more expensive, and I get a similar effect that you speak. Of course, that Panasonic can play true SVCD's, so maybe that's why.
I don't know enough about all this stuff to even attempt to help you out. I don't think there's much you can doMaybe save your pennies and buy an Apex at Walmart or Circuit City for $65. I haven't yet, but my friend who has a step higher model than my Sony (his also doesn't play true SVCDs) went out and bought an Apex just for playing SVCD's downloaded off the net. For the price, can't beat it.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15
