This is really a question about making a backup copy of a game CD which contains both data & analogue music. The game in question is an old 1997 game called Total Annihilation - don't worry, the company Cavedog liquidated. Due to CD usage and how old the CD is, I want to preserve it by not using it and making an exact copy as CD images.
Many other discussions/posts talk about either ripping analogue music, or making backup copies of data CDs. But I haven't come across topics which concentrate on a CD containing data & analogue music.
I have used CloneCD to backup my game CD. Some of the music tracks came out with noise or too much gain. One data file came out corrupted. While CloneCD is good for game data, it wasn't so good with the music.
Two questions:
- What is the best program to backup game CDs with analogue music (making best exact copy of the analogue music too)?
Is there a way to change one of the files of a CloneCD image?
PS: I don't want to use two different programs for getting the data & music.[/list]
This sounds like a setup for a future post advertising another software.
Anyone want to bet on it? -
It's the P.S. which gotcha.
To make this right and "replace" corrupt files, you HAVE to use more than 1 program.
However, I've never heard of CloneCD messing up DATA tracks, unless they're HEAVILY scratched. Maybe you should try a newer version, or another app like ISOBuster.
That CD is either a MixedMode or Enhanced MultisessionCD, and both need specific tools to get the best out of each track type.
How often do you think you're going to need to be doing this? There aren't that many of those type discs around (certainly not that many of decent/popular titles). It's more worth it to get the quality (by going with separate apps & methods) than quantity or speed.
Scott -
Originally Posted by andwan0
I would look into the Slysoft program GameJackal if CloneCD does not work. Honestly, I can't see CloneCD failing here, it doesn't make any sense to me.
Some of your problems may be more related to inferior blank CDs than anything else.Want my help? Ask here! (not via PM!)
[quote="lordsmurf
Sorry, I'm not buying this statement, sounds like BS to me. The gain of the audio won't change from merely being copied as an image.
[/quote]
Ditto. I've used CloneCd for years (actually ALL the Slysoft products) and never had any trouble with any of them. Just doesn't make any logical sense as to what's happening. Contents of a copied disc should not change from the original unless some protection is in place and sectors can't be copied correctly. -
Yes, Total Annihilation is a mix-moded CD (track 1 is data, other tracks for analogue audio). I just realised that Total Annihilation doesn't even have copy protection (from GCW)... so I didn't really need to use copy-protection profiles from CloneCD at all. I think the last time I made CloneCD images was in 2003 on a crappy CD-ROM drive.
TIP4SELF: use a good clean CD/DVD drive when making images.. & use a normal or playstation CD profile (as long as it extracts sub-channel and doesn't ignore bad sectors or errors).
Well, my old game CDs were probably naff... so I bought another new pair off eBay and they look virtually clean and new. Now am experiementaly with different CD imaging programs to see which one is best... I'll probably write up a comparison or report my findings onto their respective wikipedia pages...
1. Alcohol 120% has "Data Position Measurement"... is this good or bad? What is it really?
2. Luckily Daemon Tools Adv. has a Mixed Mode Profile. Though am confused by the subchannel options (96bytes of raw PW? or 16 bytes of PQ?). It can compress MDS/MDF format which is also good.
3. Going to try CloneCD, GameJackel, PowerISO, BlindWrite, CDRWIN, MagicISO, UltraISO, Nero, etc...
TIP4SELF: How to make flawless mix-mode images? Am not too worried about the DATA section since I can use RapidCRC and verify checksums. The hard bits are the analogue audio tracks. I did a bit of reading about Exact Audio Copy or 1-to-1 copy of analogue audio tracks. There's a program called paranoia(?). So I can do the Exact-Audio-Copy off the CD first... then do the EAC off the images and compare the 2 copies to see if they match.
PowerDVD 9.0 Ultra & Game Launching
By ChipMcC1 in forum Software PlayingReplies: 0Last Post: 12th Aug 2009, 01:10 -
Crysis Very Boring & Dull game?!
By retroborg in forum Off topicReplies: 0Last Post: 19th Apr 2009, 12:32 -
Game Consoles & Capture Cards
By Bonici in forum Capturing and VCRReplies: 4Last Post: 15th Jan 2008, 18:59 -
Creating my own subs for avi & editing subs of ogm & mkv
By retroborg in forum SubtitleReplies: 1Last Post: 1st Jan 2008, 14:33
