Results 1 to 10 of 10
  1. Member michcio's Avatar
    Jun 2008
    hi!
    I've been trying for days now to make my audio/video right synced and still can't succe. I have an .avi which I encode to .m2v using avisynth and HCenc my script is simple:
    AVISource("D:\MyAvi.avi")
    BicubicResize(720,480,0,0.6,90,0,504,276)
    I've been forsed to resize the movie into 720x480 (framerate is 23.976 so I want it in proper NTSC settings and otherwise HCEnc gives me the resolution/framerate warning) and therefore I've added the BicubicResize line.
    now after encoded the .m2v I have both tried to encode the ac3 by:
    1) open my .avs in virtualdub -> take out the wav (full prcessing mode) -> convert to ac3 using ffmpeggui (192 / 48000)
    2) open my .avi and encode the .ac3 directly by using ffmpeggui
    have also tried to change AVISource to DirectShowSource but didn't help
    (after each method I mux both audio and video streams into .mkv using mkvmerge GUI to see if they get's synced but as said as far I can't get it working
    what am I doing wrong?
    thankfull for answers!
    michcio
    take a look at my DVD-authoring guide :)
    https://forum.videohelp.com/topic353434.html
  2. What's the frame rate of your AVI file?
    What's wrong with the sync in your MKV file? Is it off by a constant amount for the whole video? Does it start in sync and get progressively worse as you get further into the video?
  3. Member michcio's Avatar
    Jun 2008
    thanks for answering
    the framerate of my AVI is 23.976 and the audio is out of sync trough the whole video (audio comes a lot too soon then the video)
  4. Set an audio delay in MkvMerge to get the audio back in sync: hilite the audio track in the "Tracks" section, then on the Format Specific Options tab set the Delay.
  5. Member michcio's Avatar
    Jun 2008
    yeah that's what I'm tring to do right now seems like there need to be 24-25 sec. delay...but is this really the "right" way of fixing that problem? I mean shouln't I make the .avs more properly then just resizing my .avi to proper NTSC AspectRatio?
  6. You could cut 24 or 25 seconds off the start of your video instead.
  7. Member michcio's Avatar
    Jun 2008
    yeah :P...oh this was kind of hard, can't get it right..don't know exactly how much delay I should add to the audio...tested with 25 and 24 and both get's wrong ...the audio seems like it begins at 24 sec..so why doesn't that delay work :S
  8. Member michcio's Avatar
    Jun 2008
    maybe the audio get more and more unsynced futher in the video and that's why it gets wrong...
  9. Member michcio's Avatar
    Jun 2008
    yes finally I get the right ms 24200 :P thank you for helping me out jagabo
    regards
    michcio
  10. Glad you got it worked out...
