Hi,
I have quite a number of large 720 mkv files and am running out of server space.
I also have some problems with high bitrates as my networks cant sustain more than 3MB/s.
So for MKV file with only one audio stream I use videora Appletv converter with which I make some mp4 files with 2.4 Mb video (no resolution conversion)and 160kbs audio.
My problem is that I have many mkv files with multiple audio and sometimes 2 subtitle tracks.
Any tool out there with which I could reduce the bitrate of these while keeping the two audio/subtitle tracks?
many thanks,
Try this: https://www.videohelp.com/tools/HDConvertToX
Its a free tool. Here is the "home page" http://forum.doom9.org/showthread.php?t=145577আমি বাংলায় গান গাই -
Thanks,Originally Posted by src2206
I am installing it now and will give it a try!
In the case of my dvd resolution dvbt ripped TS files (Hauppauge wintv 7/ hvr900H) , I also have two audio streams.
I would like to cut out the commercials from these files before reencoding.
Any good ts editor that can handle several audio stream and subtitles?
many thanks for the help.
You can try to load the file in standard editors which can handle like HD contents and try to edit things out. Regarding removing Audio streams, I think you can do that while using HDC2X.
Or you can convert first and then use an editor for that type of file to edit it. Which file type you want your results in?
For this you can try Handbrake, an excellent tool for converting between different formats.So for MKV file with only one audio stream I use videora Appletv converter with which I make some mp4 files with 2.4 Mb video (no resolution conversion)and 160kbs audio.
http://handbrake.fr/আমি বাংলায় গান গাই
What's the most "Device Compatible" container? is it, .mp4 or .mkv?
By thezanny in forum Video ConversionReplies: 11Last Post: 3rd Jan 2012, 09:07 -
Remove the mkv container(or convert) to reduce lag
By JoeJoeJoe in forum Video ConversionReplies: 10Last Post: 21st Jul 2010, 17:05 -
mkv 2audio/1subtitle to Xvid/mp4
By felix in forum Video ConversionReplies: 2Last Post: 30th Jun 2009, 07:29 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 19:19 -
how to add the correct aspect ratio flag in both an mkv and mp4 container
By graysky in forum DVD RippingReplies: 2Last Post: 22nd Sep 2007, 14:18
