I have used my Sony DCR-DVD505 CAMCORDER FOR THE PAST 2 YEARS AND THE VIDEOs THAT I SHOOT are GREAT WHEN VIEWING back ON MY Compaq computer. I use the windows media to view the videos on my computer. All movements on the videos look smooth and clean even when I pan from side to side or slowly zoom using the remote control feature. But when I edit these footages using Adobe Premiere Elements and then I render and encode the video clips that I like, before burning the final edited versions. I have a problem with the final burned DVD because the movements of the filmed people have a blurring effect and their arm leg movements are not fluid like in the original video that I shot. I am using the NTSC format for the Adode software editing needs.
My computer is running an AMD processor 64 x2 at 1.6 GHz with 256 KB cache and 2GB of RAM.
How can I get better results using the editing programs? Besides not panning or using the zoom feature.
I also have Sony Vegas and Sony DVD Architect Studio that I can use but the Adobe program seems to be easier to use..
Can somebody explain the technical background for Rendering and Encoding videos?
Thank you!
Jim
It sounds like you are deinterlacing. Can you post a few seconds of motion?
Describe your TV.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Does packaging format of videos affect rendering quality?
By MarcMiller in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2011, 16:27 -
tips for exporting/rendering videos to be burned to DVD's?
By johnphenomenon in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2010, 21:03 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 08:12 -
Raw HD Videos Look Great, Crappy After Rendering in Sony Vegas HD 9.0
By GonzoSauce in forum Newbie / General discussionsReplies: 1Last Post: 8th Aug 2010, 16:39 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 22:13
