I'm currently looking for a Good Quality MiniDV Camcorder for about £300 each. I'm looking at getting two of the type I get.
I know it isnt enough for the £1000 + Pro Models but was wondering what was the best quality I could get for this budget.
Look at the Canon Z models for new.Originally Posted by mkkid28
For MiniDV format you may find a used pro model in your price range. I'm not sure if Craig's list has caught on over there. A used camcorder evaluation is best done in person. Over here people are dumping great SD cams for dubious HD models.
Also look at the wonderful Canon HV20/30 HDV cams (also record DV) that are just above your price range.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Cheers, I'll have a look.
Would the camera Panasonic NV-GS230EB-S be any good. It has 3CCD, which I've heard is pretty good for the Lens Type? -
You should read the reviews. I recall that model had low light issues.
What about the Sony HDR-HC3, HDR-HC5 or HDR-HC7 models. Can get these Pre-Owned from CEX here in UK. I've read reviews for them over on some UK websites and they seem to get good reviews.
Need Sugestions for Camcorder with mic input under $300
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Apr 2012, 21:07 -
MiniDV playback quality on different camcorder
By marksk918 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Dec 2011, 12:08 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
Camcorder - DV? MiniDV? DVD? HD? - What?
By MarineMom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 28th Dec 2007, 20:05 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
