Hi!
I have been searching about this for ages! And I cannot find any program what would do that.
I got this video:
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 16mn
Bit rate : 5 192 Kbps
Nominal bit rate : 5 326 Kbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.860
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.246
Stream size : 4.96 GiB (76%)
Writing library : x264 core 67 r1145 d2e1e1c
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=5326 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 16mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 1.44 GiB (22%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
And I need to convert the MKV to AVI. What program should I use?
Make
Results 1 to 11 of 11
"Sharing is Caring"
Why? What are you going to play it on? or are you going to edit it?
If you want to it work on for example a divx dvd player you must also resize it. Reconvert using handbrake or xvid4psp, use the avi hardware profile.
If you want it to work on xbox360 or ps3 or mediacenters it may be enough to convert to mp4 use gotsent or mkv2vob. No video reconversion. -
I want to convert it to AVI so I can use it into AVI ReComp to add permanent subtitles and then playback with WD TV
"Sharing is Caring" -
Here's a link to a very complicated HOWTO:
how-2-do.blogspot.com/2007/12/how-to-convert-mkv-files-to-avi-with.html
A simple way would be to use MKVMerge and add the subtitle file to the MKV container. Since you're using the WD Media Player you can play the MKV file directly and select the desired subtitle. The latest WD firmware states it adds additional subtitle languages. -
I need to use the AVI ReComp to add subtitles because I need to add black borders behind the subtitles to they see much better. My das eye sight isnt that good anymore so he need better subtitles
Okay, after experimenting myself I think I understand what you are trying to do. Since you want to add black borders to display the subtitles on (so that there are white letters on the black border area for contrast) you will probably lose quality. The only way I was able to accomplish this was to change the aspect ratio of the video from 16:9 to 4:3 in AVI Recomp in order to get the borders.
What I think you're looking for is something like Closed Caption/TeleText where the white text is displayed in a black bar area within the video. I have not seen an application that can do that. -
No I don have to change any aspect ratio. I could add those borders but AVI ReComp dosent support MKV files. So i need to Convert MKV to AVI.
If all you need to do is convert from MKV to AVI, I have found that MediaCoder is the fastest and easiest way. It has a new web based configuration page. When you launch the application it starts the configuration page in your browser (Firefox) and all you do is select the settings you would like. If you need to get the subtitles from the MKV file you can extract them with MkvextractGUI. Good luck.
mail2tom. Can you help me using that Mediacoder. Im just getting 0yte file output
"Sharing is Caring"
MKV to AVI without quality loss - for watching on DVD player
By mr-scarface in forum Video ConversionReplies: 19Last Post: 17th Apr 2013, 17:59 -
Yet Another MKV to DVD without quality loss-Topic?
By SoberWarlock in forum Video ConversionReplies: 2Last Post: 10th Nov 2011, 07:26 -
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 08:09 -
Add text to MKV or AVI files...Without loss of quality...
By jaseemkannur in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 05:36 -
What is the best/simplest .mkv to .avi (xvid) convertor? (no quality loss)
By loveranger in forum Video ConversionReplies: 11Last Post: 21st Jan 2010, 23:07
