    May 2007
    I have a software program called "Aviscreen", which records what's on the screen into a video file. So if i go to a particular site, click on some links, or do whatever, this software will record what i do into a video file. It can be a DivX file, an XviD file, an Mpeg2 file, etc.
    Can someone give me a few tips on how to use the new DivX release to capture something in HD? Is it self explanatory when using the software? Do i need to know some advanced things about DivX as far as frame rates, dimensions, etc?
    Any tips you can give me, i'd sure appreciate.
    thanks!
  2. Certification Profile: Unconstrained
    Encoding Presets: 0 (fastest)
    Rate Control Mode: 1-pass quality-based
    Fixed Quantizer: 2 or greater. (2 is very good quality, large file size. 3 is fair compromise of quality and file size. Bigger values give lower quality and smaller files.)
