If I'm already using the maximum SVCD bitrate possible as CBR, is there any reason to use VBR setting? Or would I only use VBR to make longer SVCDs and thus drop the average bitrate below maximum.
I'm satisfied with how much SVCD material I can put on a 700MB disc at 2600kbps, so could VBR settings even improve my SVCDs?
The last civilization will not be another civilization. It will be that long stretch of realization to which all other civilizations have pointed.- A. Miller
no vbr wont improve quality but it can achieve the same quality in a much smaller filesize. Using vbr can turn a 6 cdr rip into a 3 cdr rip with the exact same level of quality.
If your video is very short or you dont mind using extra cdrs than cbr is fine.
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 15:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 19:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 15:28 -
CBR VBR Discussion
By josel in forum Newbie / General discussionsReplies: 11Last Post: 19th May 2007, 20:51
