hello there
i know this question has been asked for a million times already but i searched and couldn't find a thread that really helps
after installing windows home server on my main pc
i am now placing all of my video library in it
it contains avi,mkv,mpg and many other formats for alot of HQ/HD home movies and some music videos
now i want to convert my whole library into an xbox or mce friendly format
but i want to do it without loosing the quality of the video or audio
is there a program that can do that for me ? and if it has a batch conversion option or the option that delete the source after it will be even more great
i am willing to buy the software
regards
ahmed
use wmv if you want 100% xbox 360/mce compatibility.
Edit - payware like corel dvd copy 6 is very user friendly. Of course you have to have the dvds decrypted prior to ripping. But it can do it off the harddrive if ripped first.
There are others out there of course. Check out the tools section.
edit2 - you will lose some quality on any conversion. How much depends on the end bitrate you use and the desired file size. To some the loss will be neglible. To others it will look horrible compared to the orginal.
Another option is streaming to the xbox 360 with something like tversity. Then it does the transcoding for you leaving your orginal files intact.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Like I said corel dvd copy 6 is very good but it is payware.
There are plenty of other options too.
https://www.videohelp.com/toolsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thanks again yoda for the replay
isnt the corel a dvd burning program ? or does it do conversions as well ? -
The one I mentioned does do conversion.
Encode my H.264/AC3 .M2TS HD PVR video to Xbox friendly format?
By hopeSOLO in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 12:29 -
Converting BR to Edit Friendly Format
By thunderclap82 in forum Video ConversionReplies: 1Last Post: 29th May 2010, 11:52 -
Best Conversion Format for all USE Xbox360, PS3, iTouch, WDTVLive
By eruiz@lgwonline.com in forum Video Streaming DownloadingReplies: 4Last Post: 9th Feb 2010, 19:31 -
conversion from vhs video to Pioneer 520 DVR to Computer friendly format
By newguy23 in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 02:32
