In an earlier thread, I was advised to use Aften or FFMPEG to convert the audio in a DV-AVI file to AC3. I assumed that the Aften gui would accept the .avi file as an input, but it will only accept .wav files as an input. Do I need to demux the AVI first and then input the resulting .wav file into Aften? On the other hand, FFMPEG will accept the .avi file as an input, but when I add the .avi file as an input a "Floating point division by zero" message pops up. And although it nonetheless appears to convert the audio properly, I'm a bit concerned about the "floating point" message; is it potentially introducing a problem?
Might be VBR MP3 audio. That causes odd problems with some programs. I usually use VirtualDub Mod and save out the audio with full audio processing as a WAV, then use ffmpegGUI to convert to AC3. But Aften should work similarly.
If you want to find out if you have VBR audio, Gspot will tell you, though so will VD Mod. -
Don't know if the FFMPEG message means anything critical. I do the same as redwudz, opening the DV-AVI in VirtualDub, then save the wav as a separate file (direct stream copy of the source). From there, the AC3 is done with Aften. (I use Aften with the Wav to AC3 Encoder GUI.)
Aspect ratio and conversion issues with an AVI file.
By destino in forum Newbie / General discussionsReplies: 3Last Post: 13th Mar 2012, 06:30 -
ffmpeg: an image to video conversion question...
By mehmedean in forum Video ConversionReplies: 14Last Post: 31st Jan 2011, 19:18 -
Question about FFMPEG WMV conversion
By shaktar in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 08:46 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
mencoder, convert mkv to avi + ac3. sound issues
By clavain in forum Video ConversionReplies: 1Last Post: 29th Jan 2008, 17:02
