I have some file conversion software (Any video converter) and IMG burn but sick of messing with it.
Very simply, I want to transfer FLV video to DVD in the proper DVD format (playable on a standard DVD player).
Maybe I can do it with my 2 programs above but not having any luck.
I would just as soon buy (or not) one program that will do it all.
AVS video converter? (haven't researched these programs much yet).
Please, if anyone can suggest a simple -- just a few clicks program that will get the job done, I'd
appreciate it.
THANKS much.
Quality method discussed here: http://www.digitalfaq.com/forum/showpost.php?p=8437&postcount=10
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
What's the best FLV converter + best method to create FLV's from pure video
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 19:23 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11
