I have a motion menu DVD with foreign language, now I want to add some word into motion menu while the structure of dvd is not chance (hightlight is still working)
We can use any video editor to add notes to motion menu.
Hoping every will help me. Thank you so much.
For example:
Orginal motion menu
After insert into motion menu, it is a new motion menu
You have to change the highlight and selection info. Do it with PGcEdit or DVDRemake Pro.
I'll assume you know how to reencode the motion video while adding the new text. Follow this guide which discusses what you want in detail:
https://forum.videohelp.com/topic313743.html#1606732
Done correctly, it'll play as originally, but with the new text.
Edit DVD and keep menu
By Batmeat in forum Authoring (DVD)Replies: 6Last Post: 8th Mar 2011, 23:51 -
how do i edit menu connections on an existing dvd?
By animalia in forum DVD RippingReplies: 7Last Post: 14th Jun 2010, 04:42 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 08:13 -
Can you edit DVD menu without going through long rendering?
By johnharlin in forum Authoring (DVD)Replies: 3Last Post: 23rd Aug 2009, 23:25 -
PowerProducer - edit dvd menu template
By kj1983 in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2008, 19:37
