Okay gonna try this again hopefully this time with some success,,,
this is my file...
I want to compress this large hd file down to 8-10Gib......
thinking of MKV
want to keep the full HD and 5.1 AC3
Have tried Ripbot but wasnt a fan...
Any Suggestions would be great...
Especially if it is a good MKV tool program
thanks
Cam
General
Complete name : G:\NVEExport.0003.mp4
Format : BDAV
Format/Info : BluRay Video
File size : 29.1 GiB
Duration : 2h 55mn
Overall bit rate : 23.7 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Duration : 2h 55mn
Bit rate : 22.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.361
Stream size : 27.5 GiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 2h 55mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Video delay : -33ms
Stream size : 482 MiB (2%)
Results 1 to 11 of 11
okay my above 30gb file is out of sync...
i have 2 options
1 just do the origanal file which i have put the info below,,, have checked and its not out of sync....
2. Demux the 30 gb file....and redo it...
really dont want to do that again...
i used nero vision to make the 30gb file....
here is the media info on the origanal file...
General
Complete name : E:\WWE- Backlash _0004.010.Joined.ts
Format : MPEG-TS
File size : 14.5 GiB
Duration : 3h 8mn
Overall bit rate : 11.0 Mbps
Video
Menu ID : 129 (0x81)
Format : AVC
Format profile : Main@L4.0
Format settings, ReFrames : 4 frames
Duration : 3h 8mn
Bit rate : 9 856 Kbps
Width : 1 440 pixels
Standard : Component
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.211
Stream size : 13.0 GiB (90%)
Audio
Format : AC-3
Duration : 3h 8mn
Bit rate : 384 Kbps
Video delay : -1s 32ms
Stream size : 517 MiB (3%) -
okay fixed the line distortion.....
changed the bit rate from 1500 to 5800.......
and the deinterlace to slow..
it was set to none...
Now the long wait...
transfering at 1.2fps
3hr file...
saying 80hrs... -
They all are front ends for x264. If you use the same settings, same filters, same x264 version...guess what... it will take the same amount of time
You can speed it up by using lower quality settings, or slow it down by using higher quality settings. If your list specs are correct, it's much faster with newer hardware you might consider getting an upgrade
So the "distortion" was from interlacing that you forgot to take care of? -
what do you normally set the deinterlace to ...
i have mine right now to slower....
i changed my bitrate back to 1800 on film setting
found that looks better.... -
trying ojo soft total video converter....
seems good on the cpu but got to play with the bite rate...
will google that... -
all encoders are cpu hogs. you can set handbrakes cpu priority in tools/options/cli. the lower it's priority the longer the task will take.
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21 -
Need To Compress Large AVI For Youtube
By r04dw4rri0r in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2010, 11:18 -
How do I compress a large .FLV file to a smaller .FLV file
By goheadtry in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 01:13 -
Compress Quicktime File?
By videodirector in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 20:29 -
How Do I Compress a File?
By The Monkees in forum Video ConversionReplies: 3Last Post: 11th May 2007, 18:38
