Which AVI to MPEG2 file conversion application(s) do veteran converters recommend? Thanks!
Read my blog here.
Sorry, I'll be more specific. I intend on screen-recording off my pc using "CamStudio," convert the resultant AVI file to an MPEG2 file, then import that MPEG2 file into Womble's "MPEG Video Wizard DVD" for editing and authoring? What application best serves the need to convert those CamStudio-generated AVI files into MPEG2 files that will eventually be burned onto a DVD? Thanks again.
I like the free HCEnc encoder, but you need to write an avisynth file to do the resizing and to load the video, then load the avisynth script into HCEnc for encoding. AVStoDVD automates this process. If you output a combined MPG programme stream from AVStoDVD, you can edit this in Womble and author. Womble won't have to do any re-encoding because the the MPG file will be DVD compliant.
Read my blog here.
Camcorder DV-AVI to MPEG2 for WDTV Live - What software
By piperpilot12w in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2010, 11:26 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 06:59 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42
