  1. Installed the latest version of AVISynth plugins for Premiere and the files installed correctly, but I don't have the choice for that export option in settings. Anyway to get this to show up in the list? I'm following the instructions to the "T".
  2. You should not have this problem if you change the extension of the plug-in file to *.prm and copy it to:
    C:\Program Files\Adobe\Premiere 6.0\Plug-ins
    Or your Premiere Plug-in folder.
    Did you scroll down to the end of the export list? Usually it's on the last one and you need to scroll down til the end.
