http://www.amazon.com/JVC-DRMV100B-Upconverting-Recorder-Built/dp/B0015IL57I
I am not sure about the best place to post this - please feel free to move it. It is "capturing" in the sense that it is taking the analog vhs and making a dvd out of it.
Does anyone have one of these, or have any first hand experience using one? I would appreciate your input. I am looking at the pro's and con's of doing computer+high quality VCR+TBC+etc VS a machine like this one. The task is to create DVD's out of commercially made vhs and svhs movies that are in pretty good shape.
Results 1 to 12 of 12
not that one. but any all in one will probably respect the macrovision encoded on the commercial tapes and not convert it to digital.
My Walt Disney do.Originally Posted by Haopengyou
Neither Godfather 1 or 2, Star Trek TMM, Get Shorty or many others have it.
I know my copy of the Terminator does, but True Lies doesn't.
When I was copying my tapes to disk, I found that a third had protection. -
No.
I've yet to come across a PAL tape....be it from Europe or Australia....that I could not easily copy. I'veOriginally Posted by guns1inger
used both SCART and S-Video connections with no problems whatsoever with my Philips VR1200 machine.
First to a Philips DVD Recorder...and now to my computer via a Hauppauge PVR-350....never a copy problem. -
I copied my (NTSC) tapes to my Panasonic recorder that honours Macrovision.Originally Posted by hech54
The protected tapes were run through an old Radio Shack 'Video Stabilizer' -
Que?Originally Posted by hech54Want my help? Ask here! (not via PM!)
'nini' might be more appropriate for Swahili. (What?)
Porn tapes don't usually have Macrovision, but no one probably needed to know that.
But I would bet you will run into more than a few commercial US VHS tapes with Macrovision and that may be a problem for a VHS/DVR combo unit.
Considering the price of that unit, I would look into separate VHS player and DVR recorder, then if you do run into Macrovision, you could insert a stabilizer between the units. -
Hi haopengyou,Originally Posted by Haopengyou
Have you considered using a video stabilizer?
Opinions on a VHS Digitization Project
By Eternal-VHS in forum Capturing and VCRReplies: 13Last Post: 29th Dec 2011, 04:44 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
opinions on method to convert DVD to MPEG2 lossless
By fotty in forum DVD RippingReplies: 14Last Post: 21st Feb 2009, 07:48 -
AAC, AC3, or Copy Stream from DVD, need opinions
By oldjoe911 in forum AudioReplies: 3Last Post: 7th Sep 2008, 12:08
