Im sick of all these video converters out there. Ive only tried 2-3 myself, and dont fancy going through them all 1 by 1 lol.
What would you say is the best AVI 2 DVD converter there is?
Thanks guys
AppzBeWareZ
Join our AppzBeWareZ. Email us for more details. Appzbewarez@googlemail.com
thmks guys, i already am using conertxdvd 3.5. dont get me wrong its a great app and the menu u create are cool, but it takes quite awhile, or do they all take this long. thx
appzbewarezJoin our AppzBeWareZ. Email us for more details. Appzbewarez@googlemail.com -
What is "too long" for you? Conversion involves an unbelievable number of mathematical computations. Depending on computer speed, conversions can take longer than the play time of the video itself. Only a few generations of computers ago, it was an overnight deal. If you have the latest multiple-core computer with maxed-out ram and a fast hard disk, then things will progress much faster. But don't expect instant results.
I would also recommend ConvertX if you don't want to get into a bit more complex and time consuming 'fine tuning' of each and every conversion.
And no matter what 'converter/encoder' you use, speed is mostly dependent on the encoder settings and the speed that your CPU can run the encoder/codec.
On a base level quad core ConvertXtoDVD takes around 20 minutes to convert a 90 - 120 minute film. Twice as long if you use the registry hack to get 2-pass encoding. AVStoDVD takes around 50 - 60 minutes to do the same thing.
Given it was only a couple of years ago this was an all night exercise, <60 minutes is pretty good.
If you are finding these tools are too slow then you have to buy new hardware, because that is the only fix.Read my blog here.
Its all in the matter of preference, I like The Film Machine , some days I like to use HCenc and others i like to use CCE and Procoder . and for audio you have the options to use sonic foundry or surcode or just use aften.
TFM isn't the fastest app out there But It has plenty of options that out weighs the speed
DVD to avi best program?
By kkiller23 in forum DVD RippingReplies: 1Last Post: 15th Aug 2011, 13:27 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
What is the fastest program for DVD to avi conversion?
By danozard in forum DVD RippingReplies: 5Last Post: 13th Sep 2009, 02:54 -
best dvd to avi program
By petarone in forum DVD RippingReplies: 4Last Post: 26th Oct 2008, 16:42 -
Fastest AVI to DVD program
By mjaeson in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 05:09
