I have some videos that are 29.970 frame rate that I want to convert to DVD.
I'm going to be using Mainconcept to encode and need to ask the following:
1) Do I set the frame to 23.976 or just leave it at 29.970?
Can anyone help?
Thanks.
	apps round or name the files differently. some would call that 30fps. try it, the source shouldn't make any difference to the encoder, it will create dvd spec mpeg2 if it is set correctly. use default dvd spec mpeg2 settings for the output.
	Leave it at 29.97fps. If they're movies and are really supposed to be 23.976fps (won't know for sure without samples), most likely the damage has already been done, and the proper framerate is unrecoverable. And even if it is recoverable, you'd need AviSynth to fix it.Originally Posted by daz2712
  Convert NTSC AC3 (29.970) To PALBy DeathStalker77 in forum AudioReplies: 0Last Post: 26th Apr 2010, 22:09
  ffmpeg choppy audio from large avi but not small avi source fileBy cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38
  Convert 29.967 to 29.970By jin007 in forum Newbie / General discussionsReplies: 11Last Post: 17th Jul 2008, 14:09
  4:3 source AVI to 16:9 mpeg2By JoeMuskie in forum Authoring (DVD)Replies: 10Last Post: 10th Sep 2007, 09:52
  Questions about OPPO DV-970 HDBy animefan in forum DVD & Blu-ray PlayersReplies: 10Last Post: 12th May 2007, 08:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
