Im new here and just signed up. I want a shot where some one picks a dead rose off a rose bush, but after they pick it and while they are holding it, the rose comes to life and is in full bloom again.
How can I achieve this shot? I have tried shooting someone picking a dead rose, then shooting a 2nd shot of them picking a live rose and morphed the 2 shots together. I just did this real quick to see if it would work and did not put much time into it, but it looks promising if I actually spent some time on morphing it correctly.
However, just want to ask on here and get other ideas, if any.
Also, the rose is being picked in the winter time, and its summer here. So I was going to use photographs and build a 3D world out of 2D planes of a winter scene in Motion. Then add a photo of a rose bush. Is there any techniques that I can make the rose look like it is part of the rose bush seamlessly?
Or if I am way off, and there is a much easier way to achieve this shot, Im open to any suggestions.
Andrew
I think you would achieve better results by staging the dead rosebush in a winter scene or in front of green screen "in studio". Take the shot of picking the rose from several feet away and then switch to a close up for the dead rose coming back to life against an out of focus background. This should make more realistic movement from the bush as the rose is picked, and keep the morphing process easier to control. By drilling into the stem of the rose and bush at the break point and inserting a small piece of toothpick, you could shoot the scene repeatedly and "break" the rose stem each time.
Buy My Books
Achieve the best possible audio quality.
By Robertiebert in forum Video ConversionReplies: 8Last Post: 23rd May 2011, 09:35 -
How can I achieve a Technicolor effect in Virtualdub or Debugmode Wax?
By hbenthow in forum EditingReplies: 27Last Post: 11th Feb 2011, 11:41 -
How do i achieve this effect in FCP 5 ?
By d.ennion in forum EditingReplies: 2Last Post: 24th Jul 2010, 21:13 -
How can I achieve this "corrupt compression" effect
By tomdarra in forum Video ConversionReplies: 3Last Post: 23rd Sep 2008, 13:49 -
Software suggestion to make special effect of voice
By bambam in forum AudioReplies: 4Last Post: 17th Mar 2008, 10:40
Thanks for the suggestions.
