ok, i have brought a vcd, i stick it in my cd drive and after a few secs i am presented with a folder...which contains a further 5 folders:
CDI - contains CDI_BUM.dat, CDI_FONT.fnt, CDI_VCD.APP
EXT - contains LOT_X.VCD, PSD_X.VCD
MPEGAV - conatains AVSEQ01.dat, AVSEQ02.dat, AVSEQ03.dat, AVSEQ04.dat
SEGMENT - contains ITEM0001.dat, ITEM0002.dat
VCD - contains ENTRIES.VCD, INFO.VCD, LOT.VCD, PSD.VCD
Now wot am i supposed to do with this, it wont work with Media Player, WinDVD, PowerDVd.....I have windows XP, and have never tried a VCD before....i tried that VCDGear thing to convert the dat files to mpegs but couldnt.....wot do i do, and which are the important dat files...??
Please help!!
---WAHLA
Open Windows Media Player and File | Open from the menu. Go to the MPEGAV directory on the CD. Under the "Files of Type" box select "All Files (*.*)". You should now see your four DAT files.
Click one (AVSEQ01.dat for example) and then click open.
Good Luck,- bewley
bewley's mp3PRO Rock
classic/metal/new rock streaming 24/7
Ziggy In Concert
david bowie unofficial discography -
If you have PowerDVD, load it up. In the settings/configuration, change the CD/DVD drive to the drive you are going to put the VCD in (if it isn't already set correctly).
Put the VCD in.
Press play if it doesn't start automatically.
If PowerDVD doesn't recognise it as a VCD, there may be a problem with the disc.
Regards.Michael Tam
w: Morsels of Evidence
Newbie that needs answer to a question: Transferring videos to a Mac?
By PlatS in forum Newbie / General discussionsReplies: 11Last Post: 11th Nov 2010, 00:28 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 11:58 -
Color Correcting in Final Cut Pro 7 (probably an easy question to answer)
By Huntr777 in forum MacReplies: 0Last Post: 18th Apr 2010, 12:49 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 03:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 12:34
